ml500 key transmitter doesnt work again
Old Aug 14, 2004 | 04:16 AM
KILLERLEXUS's Avatar
ML500
has any one had any problems with the key tranmitter not functionning? this will be my 2nd time bringing in the ml for a key swap reguarding the same problem,,both my keys remote cant lock/un lock truck.i have to use the key to lock/un lock the truck manuelly.
Old Aug 14, 2004 | 08:47 AM
autogunner's Avatar
Have you tried to reteach them yourself ? It might be a short time fix but you would not have to manually unlock all the time? Autogunner.
Old Aug 15, 2004 | 09:18 PM
ML500
i bring it back under warranty,, but i am afraid of what they will charge when my warranty runs out..it seems like it happens alot because at my mass dealership it has a sign saying that , mercedez will need all the keys for the car, if you are there for a remote problem.
Old Aug 15, 2004 | 09:32 PM
autogunner's Avatar
I misread your post I think. Is you liftgate the only thing that will not unlock? Also if you take it to the dealer and they have to replace the AAM or EAM then they will need both keys to reteach them, and if they install a new FBM then you will get new keys and a door lock. If only your liftgate wont open then it is probably a switch or servo in the Liftgate itself. Autogunner.
Old Aug 17, 2004 | 05:38 AM
ML500
transmitter dead,no locks can be unlocked,except w/key.
Old Aug 17, 2004 | 08:55 AM
00ML430 Bulldog's Avatar
2000 ML430
Does the key start the truck. If it does.... I would follow the manuals instructions on installing new batteries, and resyncronizing the key. If all else fail then take it to the dealer. Remember you only have a set amount of keys that can be issued to that truck.
Old Aug 17, 2004 | 02:52 PM
ML500
what do you mean set amount of keys available? dont they make keys going off the vin#?they ask everyone that has this problem to bring in all keys for the car. the car is still driveable but the keyless feature doesnt work on any of the keys for the truck,
Old Aug 18, 2004 | 07:16 AM
2000 ML430
READ HERE
Old Aug 18, 2004 | 09:49 PM
ML500
