Rear main seal
Anyone have step by step how to do the job? and where is the best to get the seal? I know it requires to remove the Transmission, and i am ok with that. Thank you!
Transmission out
Drive plate off
Rear cover off
Then it seems like the procedure says the rear cover and the rear main seal are fitted as a single unit and both must be replaced. That sounds unusual. Hopefully someone with experience in this job can chime in.
In principle this look straightforward. As with all things MB there are tricky details that are critical. Torque specs, use of sealants and adhesives, careful cleaning and deburring, and single-use parts.
Transmission out
Drive plate off
Rear cover off
https://www.ebay.com/itm/04Mercedes-...53.m1438.l2649
If it is the rear main, make sure you get OE parts, not worth it to get something non OE from ebay and have to do it again.
It’s cheaper and easier than replacing a rear seal that didn’t need to be replaced.
is there a seal on transmission side? wile i have tranny out maybe i can do that to?
