Fuel pump not turning on
Old Nov 9, 2020 | 01:48 PM
Mike Wojey's Avatar
2004 ml350
Hello I have a 2004 ml350 that the fuel pump will not turn on I just replaced my water pump and put it back together went to start it and all it does is crank there was not fuel pump noise so I checked fuse and relay both are good so I replaced the pump and still nothing while so I tried to jump the relay and I the pump still won't turn on
Old Nov 9, 2020 | 02:29 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
How did you know that the relay was good, and where was it located?
Old Nov 9, 2020 | 02:58 PM
Mike Wojey's Avatar
2004 ml350
Changed out with ones from under the hood and tested them it's located front passenger side foot wheel well
Old Nov 9, 2020 | 03:37 PM
Wrong info.
File Type: pdf
Old Nov 9, 2020 | 03:55 PM
Mike Wojey's Avatar
2004 ml350
OK, locate fuse #13 in the kick panel fuse box. Have someone turn the key to start while you test both contacts for 12v on fuse 13.
I am currently home for the night but I do believe I tested that and had no power I'll try again tomorrow after work
Old Nov 14, 2020 | 03:22 PM
Mike Wojey's Avatar
2004 ml350
Sorry for the late reply I check for power at fuse 13 and there is only 10.5 volts going to the fuse not sure where to head next
Old Nov 15, 2020 | 02:11 AM
Excuse me as I gave you the wrong instructions. With the key in the ign., place your testing device (DVOM or test light) on one of the fuse contacts, then have someone turn the key to the on position , NOT START POSITION; while you quicklly test both contacts for 12v on fuse 13.
Do you understand?
Old Nov 15, 2020 | 12:42 PM
Mike Wojey's Avatar
2004 ml350
Do you understand?
Ok so I tested it while the relay and fuse were both in and on both contacts for the fuse I get a 12.5 volts while the key is in on position (no cranking) but only for a second then drops off to .1or so
Old Nov 16, 2020 | 01:54 AM
That is exactly how it is supposed to work. It primes the fuel rail to 50 PSI .
It's time to scan for codes. Scroll through the PDF and you will see multiple codes for FUEL.
File Type: pdf
Old Nov 17, 2020 | 06:27 PM
Mike Wojey's Avatar
2004 ml350
Well that's good to know but I have scanned for codes but nothing shows up
Old Nov 17, 2020 | 10:05 PM
Mike, could it be that you dislodged and electrical connector while removing the pump?
Old Nov 18, 2020 | 06:35 AM
Mike Wojey's Avatar
2004 ml350
Well the problem only started after I changed the water pump put every thing back together and went to start it to pull out of the garage and that's when there was a problem I check all plugs that I unpluged in front of the engine maybe I got a bad sensor but not sure what they all are or how to check that there working properly
Old Nov 18, 2020 | 03:15 PM
So take a photo of of the components that you removed and point to them.
Check to see that you installed the belt correctly.
File Type: pdf
Old Nov 18, 2020 | 04:49 PM
Mike Wojey's Avatar
2004 ml350
Belt is correct according to your diagram
Old Nov 19, 2020 | 06:57 AM
Mike, do you have a code reader or a scanner?
Old Nov 19, 2020 | 07:37 AM
Buy a fuel pressure gauge (of your choice).
When the eng. is cold, remove the cap at the fuel rail and press the valve in and catch fuel with a towel.
Install the gauge, and have someone turn the key to the ON position (NO START) and note the fuel pressure. What was it?. Then turn the OFF and keep looking at the gauge. Does the pressure drop slowly or quickly? Then after the expiration of 30 mins., what is the fuel pressure?
By the way, removal of the water pump does not call for removing any of those components.
Old Nov 19, 2020 | 07:57 AM
Mike Wojey's Avatar
2004 ml350
I have a code reader I removed the sensors to open up the area more and I have took off the main fuel line going to the fuel rails to see if any fuel comes out of the line when I turn the key on nothing comes out and I don't have power running to the plug the plugs into top of the pump
Old Nov 19, 2020 | 10:55 AM
Test the GREEN wire at the pump for 12v while someone cranks the eng.
Old Nov 21, 2020 | 07:58 AM
Mike Wojey's Avatar
2004 ml350
Teasted the green wire while cranking no power there and checked the connector under wheel well no power there either
Old Nov 21, 2020 | 10:52 AM
F2 fuse #13 travels to X18 conn. A3 wire GREEN. Remove cover under left side Inst. Panel and locate conn.
Test both sides of conn. X18 wire A3 GREEN for 12v while eng. is cranked.
Old Nov 21, 2020 | 02:16 PM
Mike Wojey's Avatar
2004 ml350
My ml350 is left hand drive so would it be on driver's side? This is my connector doesn't look like the same pin out as you gave unless I not looking on the right spot
Old Nov 22, 2020 | 05:57 AM
If it has 16 pins then that is it.
There are only 2 green wires in the conn.,
The other one is A2 green in the conn.
Old Nov 23, 2020 | 04:04 AM
And what did you find?
Old Nov 24, 2020 | 05:47 PM
Mike Wojey's Avatar
2004 ml350
Sorry been busy this week and have not been back to my truck yet hoping Friday at the latest will report back asap
Old Nov 27, 2020 | 01:53 PM
Mike Wojey's Avatar
2004 ml350
Not sure what ones to check I took them apart to see where they go into the plug
