Removing headlight covers
Old Sep 17, 2004 | 09:27 PM
blurrz's Avatar
98 Ml320
anyone have a diy for removing headlight covers on a 98? im assuming that they should be relatively the same for 98-02 so that would help.
thank you very much, purchased a pair of piaa xtreme bulbs!
looking forward to seeing how they look
Old Sep 21, 2004 | 11:18 PM
WienerWater's Avatar
2002 ML500,2005 Toyota 4Runner, 2006 F150 King Ranch, Kawasaki ZX1400 Ninja, 1978 Jeep CJ7
Why do you want to remove the covers? The bulbs go in through the back.
Old Sep 22, 2004 | 08:32 AM
springerfever's Avatar
1999 ML430
Do a search in the archives. Its extremely easy to remove entire headlight assembly. Once you remove the trim piece under the headlight, simply remove the three hex bolts holding the housing and gently remove the entire headlight assembly.
Although the bulbs can be accessed without removal, it is so much easier to totally take out headlight and replace bulbs. This way you can also insure the bulbs are seated properly in the holders so you don't have an aiming issue.
