Climate control switch’s ml350w163
2002 ML 320 & 2006 ML500
Important question, is your blower motor (under the dash) running when you select heat or A/C? If it is, then you must replace the Blend Door Motor.
The Blend Door Motor must be replaced, which calls for the entire removal of the dashboard.
SBundlez (07-06-2022)
Why did you remove climate control switch’s when you were replacing the radio"
https://www.youtube.com/watch?v=ptp8my_87W4
I did this, was able to change the part, and when I turned the car on to see if it would move it did not. What could be preventing it from working?
