Is a "B service" worth it?
So i have a 2000 ML430 that is out of warranty and has about 70,000 miles on it. Usual B service is carried out at 65k miles which I didn't have done (had to buy an engagement ring [
]). THe FSS recently went negative (now showing -700), and I'm wondering if the B service is worth it to get done. I understand that it's pretty expensive (~$1300 US? not including the "necessary repairs" that the stealer is going to claim it needs), and I'd like to hear your feedback as to if it's worth it.I've recently had the brakes replaced (pads+rotors) to Porterfields, and I have replaced the dust filter in the cabin.
Thanks!
riz
BTW, if you live in northern VA, which stealership do you take your truck to? MB of Alexandria, or American Service Center?
Flexible Service System - A-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
*Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
Flexible Service System - B-Service
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
For Model Year 2005 vehicles
The Mercedes-Benz Maintenance Plan makes caring for your 2005 Mercedes easier than ever. The service intervals are fixed and predictable - every 13,000 miles or one year for most vehicles.2 Your car will even remind you - about one month before it's due.
Your dealer provides a Service Welcome that includes a first visit (between 1,000 and 3,000 miles) and your first tire rotation (before 6,500 miles) at no charge.
Thanks!
riz
saturnstyl,
It wasn't my intent to offend anyone with a joke about the "stealer," but please don't assume that I'm trying to save a few bucks by not getting the truck serviced.
I take good care of my truck and just wanted to know if the B service maintenance package offered at a dealership was worth getting (for the cost and actual maintenance done), or if an independant repair should was a good alternative.
a. They were expensive
b. Frequently they were slipshod
c. They often forgot to stamp the service booklet
d. Often returned the car with oily finger prints on the trim
e. When I had a problem which wasn't strictly covered by warranty - it was 'tough luck'.
f. IMHO the added value of dealership service history adds little to the value of the ML when the resale value is down the pan. Why pay a significant % of the value of the car for little more than an oil change and bunch of inspections (read looking for more repair work at extra $$$) ?
g. I can do a better more thorough job myself at a fraction of the cost and much less inconvenience.
Finally providing you keep receipts of your non dealer servicing they are not legally able to decline warranty work - even goes for some performance mods/
But as Saturnstyl rightly says - they may cut you some slack if you've been a good little ML owner and always had your ML serviced by them
However, you or a third party shop can do the work as well. The choice depends on your finances, how long you intend to keep the car, etc.
I bought my 2000 ml430 last may,the factory was up last nov....I purchased starmark for a year.....my first service is in 200mi...will I be paying for this???? does starmark cover basic service checks???? I really would like to know this before bringing it in for a $300 oil change.....thanks!
A & B not worth it I agree. I think people are nuts for owning a MB out of warranty now.
