Engine Oil
I' ve just checked the dipstick meter and i realize that the oil color looks like
brown - dark, althown the oil level is at the max mark. Regards ML 350 driver!!
Will the FSS of the older model truck understand the nature of the newer oil?
You can identify it as it is bright white, and appears to be wrapped by hot glue in a spiral pattern.
Mercedes will still recommend you follow FSS intervals, which are valid for your particular year model....
FSS has been eliminated on 2005 and newer cars, replaced by a standard 13,000 mile service interval on all models, except AMG cars get a 10,000 mile interval.
I don't care for any of it, I use a fleece filter, mobil 1 0w40 synthetic and change it every 3,000 miles. It doesn't cost me anything, and I am very particular about such things.
If I am not wrong FSS senses the quality of the oil to decide when its oil change time.
An Improved filter would mean longer times before the oil gets dirty enough for FSS to sense a change is needed.
This would translate to longer times/more miles between oil changes..
Does that make sense?
Why would MB take FSS out for the newer models and instead make it a standard 13000 mile oil change?
Oil should be changed as and when it needs a change, and I thought that's what FSS was all about...ensuring that oil gets replaced at the right time irrespective of miles/time intervals..
FSS was confusing to many people also, MB is trying to change things to be more friendly to the customer.
Would putting in the newer improved oil filters lengthen the miles/time span between subsequent oil changes? Its not just about the 1-2K miles extra that I get between oil changes, it also would mean fewer trips to the dealership & possibly improved engine life/performance.
