PS MOD: Quad Exhaust Pipes with ///AMG Bumper/Apron
Brabus K3
I've done this image with fireworks.
The tips are the one of the chrome pack and are screwed to the exhaust pipe.
You would have to buy 2 tips as spare parts, then weld them with the original one and put some pipe that interconect the two.
You would also need to cut AMG bumper; the one of the image is the original amg bumper cut.
I have respect the proportions so the space is enough but just enough to put the quad tips.
Best Regards.
Best Regards.
ML 320 CDI
Ok, I didn't see in the first place that it was made with computer. I thought it was an accessory from AMG.
Anyway, you can be proud of what you have done since I believed it was real!!!
ML 320 CDI
Originally Posted by rubensans
It will be real;
I anyone done it before, I will do that in september.
Best Regards.
Best Regards.
Brabus K3
Don't know the work that it has, but seems to only have to cut bumper and weld the new tip with a tube to the existing one.
Best Regards.
Best Regards.
ML 320 CDI
If I remember well you'll have a ML 320 CDI. If you modify the exhaust (even if it's the very end of it), you'll modify the gas flow. This could have consequences on the turbo's operation and since the new V6 CDI are more than optimized, perhaps it can cause troubles like loss of power or, even worse, damages in your engine.
Be careful of this kind of "home made" modifications.
ML 320 CDI
I don't think I modify the exhaust flow of I take it from the 1rst tip.
Best Regards.
Best Regards.
But perhaps you're right and you won't modify enough the flow to cause troubles.
If any other member could enlight us on this point... feel free.
