Brabus Door Panel Leather Trim
I have decided to add some brabus products to my ML. I have ordered and yet to receive the chrome door lock pins. On tuesday night i picked up the led illuminated side skirts and leather door panels. Yesterday morning I dropped of the side skirts at my boddy shop to get prepped and painted. I then went to my installer to get the leather panels put on. I must say it really does enhance the look of both the door and interior as a whole. The install appeared to be pretty straight forward. The hardest part was to make sure the templetes the came with the kit were perfectly aligned. The kit comes with everything you need although the instructions were in german only. The kit includes the 4 panels, 1 templete for the front doors, 1 for for the rear doors. and a drill bit that has a wadded material on it so you only drill the holes in the door panel to correct depth. The instructions did not require the removal at all of the door panel. All in all it took maybe 45 minutes or so for them to be installed. My last and toughest decision is whether to get 22 Monoblock S's or Monoblock VI's. I like both wheel. What are your opinions on the wheels. Which do each of you prefer and why ?
Ant,
got your mail. when i get a moment i would like to check it out. i will touch base with you. In getting back you on the other post I ordered my stuff through Action in Lodi. Did you ever get around to taking those close up pix of the side skirts for me ? I beileve you said you needed a day or two in the other post. thanks
