SRS Malfunction-again..
Old Jul 23, 2007 | 05:39 AM
BruNo's Avatar
07' ML350
any ideas what causes the SRS malfunction??? i got this error msg the 2nd time around, after it was reset by the dealer last April. dealer said it was just a false alarm.
Old Jul 23, 2007 | 06:36 PM
wheld280's Avatar
2005 SLK350, 2006 ML350, 2006 CL500
SRS Malfunction
The SRS Malfunction light has come on twice in the last eight months on my wife's 2006 ML350.
In 12/2006 I took the ML to the dealer and they did the following work :
"Found airbag code 9200. Performed OP 1 of DTB T-B-91.60/93E. Replaced airbag line to steering column module. Then cleared codes and verified proper ops."
In 5/2007, light on again. Back to the dealer and they did the following:
"Found fault 9200. Inspected wiring and connections to steering column module. Found solder connections are seperating. Repaired all contacts for airbag harness in steering column. Reset computer system and recheck operation."
All the work was performed free under WARRANTY. Hopefully they have solved the problem as I am tired of taking the car to the dealer to fix a variety of problems.
Bill
Old Jul 24, 2007 | 05:14 PM
AR.Shah's Avatar
2011 E-class coupe, 2012 C-class
Usually its the plastic sensor plate in the front passenger seat which is defective, you can do a small test:
Have someone heavy sit on it and see if the SRS lamp disappears, if so then its definately the sensor plate.
Old Jul 24, 2007 | 11:47 PM
adarquea's Avatar
ML500 190E 2.3-16
I thought the srs problem was asosiated with the steering column and not the passenger seat. Thats what they told me here in Quito they also said there was a recall on it!
Old Jul 25, 2007 | 01:17 AM
BruNo's Avatar
07' ML350
i also have this "clicking sound" on my steering column, so prolly its the bearing issue, maybe this also has got to do with the srs error.
Old Jul 25, 2007 | 09:11 AM
WayneE's Avatar
'72 Suburban
I think mine has come on 4 times. Typical MB quality.
Old Aug 25, 2007 | 12:52 AM
alewifebp's Avatar
2014 BMW 550i
Just had this error pop up today. Taking it in to the dealer Saturday morning to get it fixed. Hopefully it's an easy fix.
Old Aug 27, 2007 | 01:12 PM
havacgar's Avatar
2008 C300 Sport Obsidian Black; 2006 ML350 Iridium Silver
On my 05 E320 CDI numerous SRS issues all resolved after the steering column fix......none so far on my 06 ML
