backup camera info
Old Aug 8, 2007 | 10:27 PM
joester's Avatar
backup camera info
Hi I'm getting ready to install a back-up camera in my wife 2006 ML350. Does anyone know if there is a harness under the steering which will give 12v when shifting into reverse or do I have to run a wire from the tail light?
Old Aug 10, 2007 | 02:33 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
you need to go all the way back to either the taillight assembly or the rear SAM. it should be a white or white/black stripe.
Old Aug 12, 2007 | 08:30 AM
cassiri's Avatar
backup camera
Are you installing a factory camera or aftermarket? If aftermarket, will it tie into the factory screen?
Old Aug 14, 2007 | 12:15 AM
joester's Avatar
It is an aftermarket unit. The display hooks onto you rear view mirror.
It took me a good 4 hrs to install the unit.
