Oil Change
Old Aug 9, 2007 | 12:49 AM
Ivessm's Avatar
Oil Change
Question, has anyone observed the pump apparatus that MB uses to change the oil in their cars and SUV's. I hear they no longer drain the oil from the bottom but pump it out from the dip stick.
If you have seen this pump apparatus do you remember if MB uses a pipe feed down through the dip stick hole or a plastic tube?
I'm getting setup to do my first oil change and just trying to figure out the best method to suck the oil out of the pan.
Thanks.
stew
Old Aug 9, 2007 | 05:46 PM
AR.Shah's Avatar
2011 E-class coupe, 2012 C-class
I think the method with pumping the old oil out via the dip stick pipe is the best. This is what they do at all MB garages.
Old Aug 9, 2007 | 06:16 PM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
Thanks.
stew
This is what I use. It works VERY well.
http://www.thetoolwarehouse.net/shop/MIT-7201.html
Old Aug 9, 2007 | 10:16 PM
lkchris's Avatar
'10 CL550, '12 GL550
No longer?
MB has designed for this since the '80s if not the '70s.
Old Sep 8, 2007 | 09:25 PM
matt55's Avatar
09 c63 10 c300 Nissan truck
Dutch, is the tube diameter of the MITY VAC small enough to fit a 07 e550?I assume all 07s have the same diameter dipsticks but want to confirm before I order one thanks
Old Sep 9, 2007 | 06:36 AM
DUTCH's Avatar
The MityVac comes with two different tubes to insert in the dipstick tube.
While I can't answer specific to your model, I can tell you that the one I use fits nicely in my G500 (M113), ML320CDI (OM642) and my daughter's KIA Sportage. I would hazard a guess that one of them will fit your E550, too.
Old Sep 9, 2007 | 07:29 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
I have one as well, it's the only way to do it...just a suggestion, I wrapped electrical tape, on the suction tube, at the point in which the dipstick would be fully seated. I also cut a small notch to prevent the extraction tube from aspirating against the oil pan.
Old Sep 9, 2007 | 08:25 AM
DUTCH's Avatar
That's a good point. That MityVac will pull a mighty enough vacuum to collapse the main reservoir chamber when it has hot oil in it. Ask me how I know.
Old Sep 9, 2007 | 01:09 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
MityVac
I also have had great success with the MityVac. Unfortunately, more new cars a dropping the dipstick for electronic oil readings (e.g. 2008 M3).
Old Sep 10, 2007 | 04:12 PM
matt55's Avatar
Saplegun, please explain what you mean by cutting a small notch to prevent the extraction tude from aspirating against the oil pan.Where is the notch?
Old Sep 10, 2007 | 05:09 PM
Saplegun, please explain what you mean by cutting a small notch to prevent the extraction tube from aspirating against the oil pan.Where is the notch?
He means at the very end of the tube that gets inserted down into the pan through the dipstick. That prevents it from forming a vacuum against the pan surface if it was pressed against it at right angles. I have never experienced this, but its a good idea.
