DIfferences between US and European CDIs?
I wasn't surprised to discover that there's no Tele Aid in Europe, but was very surprised to find out that the Nav system installed in the European models is different from the US models and not compatable. Dang!!
Is anyone aware of anything else I need to be aware of as I take my 07 CDI over?
Your trailer wiring connector won't work, and Euro hitches are 50mm which is not same as 2 inches.
Someone over there will LOVE those amber reflectors in your headlights.
I don't know that I would ever need to tow--I have the hitch so I can tow my 300ZX each time I move, but it's VERY useful to know I can't anyway.
I knew about Satellite Radio--I will really miss it.
Remember you guys pay $1000s less than we do in Europe for ML/GL !
Also, I think in general your ride heights are different and the central locking pins hide away when locked on cars that are not for USA, whereas in the USA they always stick up a bit to help theives with packing tape open the doors! We also dont have the side indicator repeaters that are in the the bumpers on US mercedes, and you have a button inside the trunk to let you out when someone shut you in.
BTW, we have DAB radio here (digital terestrial)
Cheers
Richard
I don't quite understand the part about--ride height and central locking pins....and are theives a problem??
The satellite radio is really nice when driving cross country because you can listen to the same station, instead of having to find a new one every 120 miles or so. And I like having around a hundred choices, including BBC, which provides better news than I can get around here.
Yes, (a) thieves are a problem in many cities (i'm sure thats the same everywhere) and as the cars dont have deadlocks (i.e the door pins / inner handles are disabled when car is locked remotely) having pins you can pull up easily with some packing tape would mean very easy entry. (b) the doors unlock in an accident in anycase, so having access to the door pins once you break the glass in an emergency isnt that useful.
UK cars get increased theft protection over the default (glass break detection in the ML/GL/R for instance) - I'm sure other markets do as-well.
I don't suppose we drive that far regularly here - I know you US guys drive for miles given half a chance. DAB radio I beleive gives you the same ability here, and RDS also will re-tune to the same station on different frequencies (where it exists) I think. DAB radio is only available on the new S/CL and C classes at the moment.
Richard
"Hi phillip,
GPS still works with your nav, you will need to get a map disk for your new territory: those can be purchased direct from navteq. Sat radio if you have it will also not work. Radio will work but you may need to take the vehicle to the dealer to have the frequency spacing changed for your area. other than that it should be ok..."
"Hi phillip,
[edit, the mapping software and the mapping data is on the DVD, the software is for the navigation processor, the data is the map itself]
They are right about Sat radio. I dont know if MCS-II (US comand) can be coded for European radio spacing. EU Comand can be coded for US spacing - Also US systems dont do RDS text, wheres EU ones do.
Diesel prices = £1.089 per litre = £4.356 per US gallon = approx $8.60 per US gallon
Richard
