Brake Light Warning
Old Mar 22, 2009 | 09:34 AM
sdeason1's Avatar
2006 ML500
Brake Light Warning
2006 ML500. Info center constantly telling me that my right brake light is out, replace with bulb from left. Vice-Versa. Right and Left. I've replaced all bulbs. What is the problem?
Old Mar 23, 2009 | 09:01 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Make sure the bulbs were the "long life" design from the dealer or very reputable source.
Check for corrosion at the bulb socket.
I just went through my passenger side right mirror turn signal going inop. after 2 bulb assembly changes by the dealer, and on the third time, they found corrosion at the plug. So far problem solved.
Old Mar 23, 2009 | 11:05 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
i heard that there were issues with the electrical wiring in the headlights and taillights. my service advisor told me about it and how they had to re-solder the wiring.
