Phone
I also travel overseas a lot, and so far so good. Works in London, Frankfurt and Mexico. Just remember to turn OFF data roaming to avoid really expensive charges when overseas.
Also, if you have wifi at your destination, you could actually log into Skype and talk.
Have fun downloading some of the thousands of apps when you get it!
On a downside, I have the 3G as oposed to the 3Gs, and as such I do not have video or the compass. Also the text message function does not yet send pics. (MMS I think that's called?) As for the battery, it does recharge very quickly.
just remember to get the iPod interface setup in your new ride!
The Razor will pair perfectly with the bluetooth, and I have used mine extensively worldwide. Voice and transmission is crystal clear. Also the Razor can be unlocked, so I would swap out my SIM cards on overseas arrival save on international roaming fees. Not paying the extra $30/month for the ATT Apple iPhone plan is also a plus! And you can carry a spare battery for your Razor!
The iPhone battery cannot be changed without sending it back to Apple. For both phones, get a car charger and an extra wall plug.
willie
If not what is the easiest and less expensive way to get bluetooth to work with a 03 clk without the phone cradle?
thanks in advance.
joe
I currently have 2 forms of blue tooth, one on my ML55, via the blue tooth puck with VCS. This setup works fine, addressbook (limiited to only first 100 names), and when the car is still, perfect. When travelling 80mph on the freeway, the people on the other end say there's a lot of background noise.
The other one I have is an R500, with the newer generation blue tooth that plugs into the center console, and same thing as above, when driving, background noise. But the difference here is no limit as to the address book. And you can look up names and numbers via the command display.
Both are paired with Iphone 3g. So for you guys with iphones and bluetooths in your car, you should ask the other end, it sucks, i tried it myself. wife called me, while she was driving, and I couldn't hear worth s***.
I read that Viseeo or however it's spelled works better as far as voice...that's my 2 cents.
Also to add, recently travelled to france, london, and the iphones work the same as they do here, just remember to change data roaming if you want to get all your emails and surf as you do here...but crazy rates apply if you don't call ahead and get it all hooked up in a monthly rate.
