2006 ML350: Feels like rear shocks are gone
We have been noticing that our ML350 has been so jerky and slamming over small bumps, potholes, and speed bumps to the point that we can conclude that the back suspension is gone. We have 55k miles on it and we bought an extended warranty to 75k. There seems to be some "booming" sound when the back of the car hits a bump or comes down our driveway over the hump between the driveway and the main street. Its so bad now even with the new tires we placed on the car (Michelin MXV4) which is our second set of tires. The car was perfectly fine from new until about 50k miles. Any advice????
I had to replace my rear shocks at 45K miles. The service tech hinted that this was not a surprise to him, as he has replaced several 164 ML rear shocks before. It was under warranty, so I did not have to spring for the $650 bucks.
If you take off a rear tire, look carefully at the shock, and you will see a dusty coating of oil smeared to the shock tube.
Get it repaired under warranty!!
2008 ML350 4matic
please keep us posted on the outcome, I have notice a similar "hollow" thunk from the rear when hitting a sharp bump at lower speeds.....I only have 22k miles and sure hope it's not a shock issue this soon....
The noise came from a bad ball joint so the dealership replaced the right rear ball joint. However, my main complaint was when I am sitting in the back seat and someone is driving the car over bumps and small holes on the road and some patched over potholes I can feel that back suspension being jerked up and down and causing me to feel jolted and shaken alot in the back and it never used to be like this. I dont think the dealership looked at this problem or drove the car properly with any mechanic sitting in the back to notice that the ride is not supple and is not absorbing the bumps well in the rear.
So, I plan to take it back again and tell them to look at those struts. DGIturbo, how did the ride feel in the back when you had the shock problems and how did it feel afterwards?
I have an 07 ML350 with 20k miles. I just had both rear shocks replaced (1 leaking) and a rear ball joint. The tech said that the manual says to replace the shocks in pairs only.
With 4 people in the car it seems to bottom out when going over small bumps or pot holes.
We took it on vacation and with the kids in the back and full of luggage it was bottoming out a lot.
Baloo588, unfortunately I have never sat in the rear of the car when driven so I can't comment. I discovered the problem when I was rotating tires and noticed the dusty oil smear on the shock tube. It rode the same before and after, but remember I have the Airmatic suspension so it may have been compensating?
I think it could be useful for other users to know ...
