2010 ML 350
Sid
Don't worry about it...The flip side to this is that you will get decent gas mileage compared to the ML550.
In a couple of hundred miles you will not remember the difference. Since the car is new, you need to follow the brake-in procedure listed in your manual and avoid harsh acellerations for a few thousand miles. From my experience with a C32 AMG I used to own a few years back, the car accelerates much better/faster after the break in period.
There are some things you can remove to save weight (ie, spare tire and kit), but I wouldn't recommend it. There are also some tunes for the 3.5, but I don't think they're worth the money for what it gains. BTW, I just averaged 23mpg on the highway going to work (50 mile trip) on the ML350 2WD. Not bad coming from a GL450 (I averaged 19-20mpg on the highway).
The turbo lag on the X5 is much worse than on the ML....although once it kicks in.....it's WAY faster than the MB.
Sid
To help prevent unwanted vehicle roll (backwards or forwards) when taking off from a stop on an incline of 5 degrees or more, Hill-Start Assist automatically maintains brake pressure for approximately one second after the driver releases the brake pedal. The system is automatically deactivated when the vehicle is level, the gear selector is in Park or Neutral, or the parking brake is set.
Also Test drove the BMW X5 35D Diesel.
Here are my impressions:
the ML-350 Diesel seems to accelerate faster off the line than the gas. I think the 400Lbs of torque helps.
The X5 is a little slower right at first (I assume turbo lag) and then kicks in. I didn't feel as much lag in the ML-350. Shortly there after the X5 seems to take off and I am positive it is faster than the ML-350 overall. It also handles a little more sporty. That said, the X5 ride is more like my 2005 Nissan Frontier truck. (Of course the handling is better) The ML-350 is more like a Luxury car feel.
I guess it depends on what you are looking for. The ML-350 Bluetec is a fine ride. If I was going on a road trip and owned both vehicles I would take the ML-350 Bluetec over the X5 35D.
My wife is getting a 2010 ML-350 Bluetec Wednesday, I kind of wanted her to get the BMW X5 35D. But..She had some very good reasons why she liked the ML-350 better.
There is significantly more turbo lag in the X5, but it also much, much faster than the ML.
The ride quality is also accurately depicted. The X5 is rougher, but both it and the ML are both noticeably better minus the run flats.
As you suggested, my wife loves her ML, while I prefer my X5.
I thought this was an off road compromise but they could have had a softer alternative pedal map for the offroad button..... I'd ask the Dealer if there is an alternative calibration available that can be flashed to "firm" up the pedal response.
I thought it was an unacceptably soft response as well but it improved noticeably as the engine loosened up over the first 2k miles or so. It's still not great (7.5k) but better than it was before.
This is a 2009 ML320CDI.
Cheers,
Ruaraidh
