22 inch tire question.
Your suggested wheel/tire combo has an overall diameter of 29.9 inches. That is 0.7 inches more than stock AMG wheels. While that alone is unlikely to cause rubbing, you also need to know the offset. The 295/35 21 AMG package -- the closest to yours -- has 46mm offset 10Jx21 wheels. On my ML550, which has 265/40 21 tires, the front wheel offset is 60 mm and the rear is 48mm. The wheels are 9Jx21. If your wheels are much more than about 55mm offset, I wouldn't buy them without testing their fit first.
If you go with aftermarket wheels, make sure they are specifically for SUVs. I have OZ Canyons that I use with winter tires; they have a specific line for SUVs. Also, the tires should be marked XL, for 'extra load'.
Anyone know if I would be ok hauling a 6500 lb payload with that tire and wheel set up?/
