Brake Dust Shields
Old Nov 21, 2010 | 11:43 PM
mercedese350's Avatar
E350
Brake Dust Shields
Hello,
Is anyone installed brake dust shield?
Please post a feedback, picture, brand.
Happy Thanks Giving!
Old Nov 22, 2010 | 12:18 PM
lkchris's Avatar
'10 CL550, '12 GL550
These are expressly forbidden by Mercedes and are a potential safety hazard.
Most REAL Mercedes mechanics won't let you out of their shop without removing them first.
Put car wax on your wheels and the dust won't stick as much and will wash off much easier.
Old Nov 22, 2010 | 01:07 PM
aggst1's Avatar
2011 GL450, '06 R500 traded, '08 ML350 sold
These became popular in the 80s and they worked as intended (keep wheels cleaner) HOWEVER there is a problem. They keep the brakes from ventilating using the proper airflow as designed so they overheat and become a safety hazard as stated above. You don't want to use them.
Old Nov 23, 2010 | 10:30 AM
roadrutz's Avatar
'09 ML550
I use Michelin Brake Dust Repellent. I bought it at Canadian Tire. In the US, I believe Autozone sells it. It works -- it partially stops the dust from adhering to the wheel and it makes hosing it off much easier.
Old Nov 23, 2010 | 11:26 AM
aggst1's Avatar
Do you just spray it on and let it dry?
Old Nov 24, 2010 | 10:11 AM
slickdevil's Avatar
ML550, F-350
Armor All also makes a similar product called wheel protectant
http://www.armorall.com/products/vie...?product_id=33
Old Nov 24, 2010 | 10:30 AM
aggst1's Avatar
Cool, I will check it out! Might be easier to spray something like that on than apply wax and having to wipe off.
Old Nov 24, 2010 | 11:06 AM
roadrutz's Avatar
'09 ML550
Yes, but then give it a quick 30-second buffing with a soft cloth.
