ML350's with 20's interchangable for 19's
Or is this a straight swap and re-alignment?
Since you are paying extra for the 20" wheels (appearance package), I would not swap them out for 19" wheels (which are cheaper) at the dealer. Might as well trade with someone and get some cash back along the way.
If I want to use 19" rims I have to change the tires to: 255/50-R19.
Try Googling for Tire Size Calculator and check out the effect of changing rim & tire size.
Did your mpg suffer noticably?
Do the big tires at least help with off the line traction?
Thanks Greg
Thanks Greg
Surprising even with the ML's 50/50 split full time awd, it spins its 265 tires easily in 1st gear on dry roads if you have the steering wheel ever so slightly turned. I'm sure this is due to the open diffs front and rear. The 5.5liter V8 is quite powerful. I am hoping it wont spin tires at all with wider 295s.
It came with 19" stock wheels.
I don't want to loose the luxury smooth ride or acceleration. The ride is so great!!
I found some 20' asanti classy rims for my diamond white new ML.
But really need some advice on tire size.
What's the widest tire I could go on a 20" rim for my ML that will still keep my smooth luxury ride. Not rough and bumpy
I want to order a set of 20" asanti classy rims but I don't know what WIDEST tire size I can or is best to go with the 20" rims so It will still allow me to keep my smooth luxury ride. ( or if it's even possible to go with a wide tire to keep the smooth luxury ride ). I live down south and NO snow.
I really need some help with this. Can anyone help with some advice?
Tonya
Tonya
While tire models have some variance in ride quality, it is unlikely a 20" tire will ride as well as most 19s.
The maximum width depends on wheel offset and width. The ML63 as you probably know came with 295/40-20s on 10" wide rims. I would not go wider than that. But you need to verify the offset and width are compatible with your vehicle.
