Can someone tell me what this button does?
Old May 14, 2011 | 06:31 PM
theeld's Avatar
honda accord
Circled below. Thanks!
Old May 14, 2011 | 06:44 PM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I dont have that in mine, look in your owners manuel.
Old May 14, 2011 | 06:48 PM
theeld's Avatar
honda accord
The photo is from a vehicle I do not own. However I would possibly like to own it, hence I havent an owners manual!!
Old May 14, 2011 | 07:06 PM
karwerk's Avatar
14 e63s,03 e55, 69 280s, 92 500e, 95 e320, 08 lancer
switch the parktronic off i assume
Old May 14, 2011 | 07:10 PM
AMGC60-3's Avatar
Thats a good guess, could be. You can look online for the owners manuel in PDF format.
Old May 14, 2011 | 07:15 PM
Benzy550's Avatar
2011 ML550
Parktronic
Old May 14, 2011 | 07:18 PM
11w212's Avatar
11w212
Thumbs up Parktronic button
Yes,that will turn off the parktronic system on the vehicle temporarily , after recycling the ignition key it will operate again (on)
Old May 14, 2011 | 08:46 PM
Vernl's Avatar
ML320CDI 2008 all options inc air suspension
Definately Parktronic, as indicated by the P with radio waves beside it
Old May 25, 2011 | 01:00 PM
Benztech858's Avatar
2004 E55 - 2010 GL450 - 2011 GL550
Exactly, it will disable the parktronic system. The reason it is there is for days with snow or any debris that may set it off randomly.
Old May 25, 2011 | 09:25 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Such as anytime you use it in wintery conditions, or get it wet below freezing temps. Then it will beep like crazy and shut itself off if you don't push that button fast enough. The red light will stay on, leaving you with the thought that it's broken and what's it going to cost to fix.
Works perfect when it's warm though.
