how do u check the transmission oil???
Old Aug 21, 2017 | 04:59 AM
duke749's Avatar
C55 AMG
dipstick
Originally Posted by primatives
anyone know how to check the tranmission oil, other than having to go to MB themselves???? Someone at MB showed my uncle how to check it on the w163. but my dad has the w164. any help would be great thanks!!
you can buy a dipstick or make one just google there's loads of info easy to make
i change my fluid at 100 thous km it needed doing drop the pan and change filter
4.6 liter when you drop pan
2. liters when you drain with plug
i used FEBI fluid has the MB 236.14 spec
Old Aug 21, 2017 | 06:06 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
Originally Posted by Nickthegreek
Call it obsessive if you want. I call it being proactive
There is a difference between being "proactive" and being "neurotic."
Old Feb 22, 2018 | 01:57 AM
hdidane00's Avatar
2011 Ml 350 bluetec
Hello, i read your input in the forum and wondered if i could service mine at 75K its a 2011 ML350 with i guess the 7 speed 722.9 . i got the car used at 72k called dealer they said it's never been serviced. now given its never been service should i just drain it "drop pan + drain torque converter+ change filter+gasket" or just I flush it? which is the safest route? i believe manual recommends 40K one mecanictold me it's fine to do it at 80K. had a bad experience before with a Toyota which i flushed at 100k and it went belly up 4000 miles later. that's why i'm caution and this is a Merc not a toyota so obviously repair cost will be higher.
Old Feb 22, 2018 | 02:18 AM
hdidane00's Avatar
2011 Ml 350 bluetec
Old Feb 22, 2018 | 09:28 AM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Thank you for this post. My MB's are '14's (GL450/ML350) so maint may be different. But it caused me to check the manual. Both require trans flush and filter at 7 yrs or 70k. Maint manual also has disclaimer that failure to do required maint could void warranty. I know that doesn't mean MB must do the work. But now I know more than I did before this post.
Old Feb 22, 2018 | 10:09 AM
Liuds's Avatar
2018 GLE400 Gasoline, 4Matic
2009ML350 transmission oil check
Dealership told me 40k miles or 60 km to do the first trans flushing, very important because small metal debris ... break in.
Then second at 180k km, not 120k kilometers. I am in Canada, cost over 600CND plus tax.
The big issue is that to check the oil level needs a specific tool. Mercedes designed this trans no leaking. Actually, my ml350 is dripping a little bit at one hose-to-metal joint to the radiator, passenger side.
Old Feb 24, 2018 | 08:37 AM
  #32
flybd5's Avatar
My 09 550 had the same problem and the mechanic decided to replace the hose at the 60,000 mile service.
Old Feb 24, 2018 | 09:12 AM
  #33
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Those hoses are only $55 each.
Old Sep 2, 2018 | 01:29 AM
  #34
shonakim's Avatar
2006 ml500, 2016 accord
Hi Guys,
After draining out transmission fluid from 2006 ML500, I just put new fluid into the port where a red cap is in front of the passenger side, I have driven since then. I sometime have felt somewhat stiff feeling. Can anyone advise me the right location of refiller port for transmission fluid?
Old Sep 2, 2018 | 04:40 AM
  #35
Originally Posted by shonakim
Hi Guys,
After draining out transmission fluid from 2006 ML500, I just put new fluid into the port where a red cap is in front of the passenger side, I have driven since then. I sometime have felt somewhat stiff feeling shift. Can anyone advise the right location of refiller port for transmission fluid?
It seems that you do not have a 2006 ML500 but you do have a 2005 Ml. What is your full vin #.
Old Sep 2, 2018 | 04:59 AM
  #36
shonakim's Avatar
Hi Maj. Dundee,
Thank you for the quick reply. My VIN# 4JGBB75E46A070048
Old Sep 2, 2018 | 05:07 AM
  #37
shonakim's Avatar
Thank you Maj. Dundee for the quick reply.
The VIN# is 4JGBB75E46A070048. The title shows 2006 MB ML500. The red cap is located behind the right headlight (passenger side)
Old Sep 2, 2018 | 05:12 AM
  #38
shonakim's Avatar
Maj. Dundee,
The VIN# 4JGBB75E46A070048
Thank you in advance
Old Sep 2, 2018 | 05:26 AM
  #39
Yes you do have a 2006 ML 500, here is a copy of your DATA Card.
Can you take a photo of the RED cap you are referring to? There is no fill port or tube for W164 vehicles. Do not drive you truck any further or you will irreparably damage the trans.
File Type: pdf
Old Sep 2, 2018 | 05:49 AM
  #40
I believe that you put trans. fluid into the eng. oil dip stick tube. You have a huge problem.
Old Sep 2, 2018 | 06:05 AM
  #41
shonakim's Avatar
Maj. Dundee,
Now what can i do ? I think i have driven more than 500miles
Old Sep 2, 2018 | 06:23 AM
  #42
Do you own your own home?
How long have you owned the truck and did you ever change the eng. oil & filter?
Old Sep 2, 2018 | 06:33 AM
  #43
shonakim's Avatar
Maj. Dundee,
Yes I own my home. My eng. oil service has been done at MB dealership but I have not changed the eng. oil since I change the trans. fluid. The transmission oil change was my first DIY. I have owned this truck since 2009.
Old Sep 2, 2018 | 06:41 AM
  #44
shonakim's Avatar
Maj. Dundee,
Yes I own my home. The engine oil service has been done at MB dealership. I have not had the engine oil service after this happening. The transmission oil change was my first DIY.
I have had this truck since 2009.
Any suggestions?
Old Sep 2, 2018 | 06:44 AM
  #45
Before we go any further, do you think you can do your own oil and filter change by reading this PDF?
Do you have a floor jack?
Do you know a mechanic very near to your home?
Old Sep 2, 2018 | 06:55 AM
  #46
shonakim's Avatar
Major Dundee,
I do have a floor jack. I think i can do it as the PDF shows.
I always used the dealership except this trans oil change. I know a mechanic about 10 miles away and the dealership is 30 miles away.
As i mentioned earlier i drove more than 500 miles since then, do you think it is repairable?
Old Sep 2, 2018 | 07:07 AM
  #47
Hold tight, I'm preparing something.
Old Sep 2, 2018 | 07:21 AM
  #48
I hope this isn't your only car, but position it out of the way and facing the street so it will be out of commission and not to be moved again. Order the following items from Amazon and have them delivered. You need 10 qts. so order two on the oil.
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Old Sep 2, 2018 | 07:28 AM
  #49
Call you mechanic tomorrow and ask him if he has the equipment to pump in trans. fluid through the drain plug on the trans. oil pan
Old Sep 2, 2018 | 07:52 AM
  #50
shonakim's Avatar
Maj. Dundee,
I will surely do as you directed. I will also keep you updated.
