Lowered ML's: Please update on camber / tire wear.
Can I ask you lowered guys to update the rest of us on your tire wear situation?
I'm interested to hear: What springs you used (Eibach, H&R, Brabus).. Miles since the lowering.. and as well, if you replaced the front tires due to inner tire wear (Camber wear).
Cheers!
A camber kit would be perfect.. but I guess that's not the same thing you're developing if you're making something for the airmatics....
I was told that any negative camber on the front needs to be dialled out.
if theres not enough adjustment, Brabus can supply the correct bolts to do the job. Ive got the Mercedes part numbers somwhere if anyone is interested?
I didn't know Brabus made such a correcting kit for the W164. If so, please do post the part numbers. I'll assume its good to use with other springs (though the drop may differ, yielding different results but still better than nothing)
Hope it helps:-
which are too negative. Even when the values are still within the tolreances, the workshop should try to adjust them to positive.
Of course this is not always possible, on a ML they can fit different screws which are available from Mercedes-Benz.
The standard bolts are replaced using those listed below, with these bolts the camber can be adjusted to positive.
The article-numbers required are:
A0003330871-Screw
A0003330771 Nut
N000000003307 Screw
A0029905150 Nut"
Need to know... what mm size strut bolts do we have on our ML's? W164.
I'm thinking now:
Bilstein B6
H&R
and an Ingalls camber kit.
I have a lowered CLK 430 with H&R's and Bilsteins. Bilsteins work "well" but are little too harsh over sharp bumps and too soft at speed, controlling the car. I had to use camber adjusters front and rear to correct - * there also.
If you use H&R coils your camber will only be slightly - *. It's all a trade off. You won't get much of a drop but then you won't need to readjust the camber as much either. Problem being the rears will still be slightly toed in unless you re-adjust, which ever way you go. Look closely at the 164 forum photos. All the drops show the rears toed in (neg camber) rears. The pictures are taken to hide alot. Straight on rear shots showing both tires is best.
Ingalls won't work. Those are for small cars, not something as big as an ML or rear drive independent suspension type.
I'm working alot and still planning on my own rear camber adjusters but I'm still a long ways off.
I'm building a set from scratch or you'll have to find a performance or tuner shop as we call them on this side of the pond and have them build you a set of adjustable control arms.
Our ML is approx. 2" lower and now has - camber. If I want to go lower I'll have to build an adjustable set of control arms.
Good Luck
