Help on trailer hitch and connections-- anyone tonight???
Old Feb 16, 2013 | 12:01 AM
MLSEXY3's Avatar
250, WRX, ML63, CL-S
I have the Flex N gate Box with 7 pin and Factory hitch setup on 2009 ML63.
THis is made in Warren MI.
Who stocks the 7 pin plug in that can connect to a standard 4 pinner.?
Dealer item only?
Old Feb 16, 2013 | 06:53 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
You do not show your location. Therefore search on google for stores near you. Then its only a matter of calling them for stock on hand.
Old Feb 18, 2013 | 08:24 PM
jblair's Avatar
ML350 4Matic
I got mine at Uhaul (dealer referred). Make sure to specify anolog or LED trailer lights.
Old May 9, 2013 | 02:18 AM
Adaline's Avatar
RV
Internet search provide relevant solution but in hurry it is better to try RV and box trailers solution as I am regular user of this.
Old May 9, 2013 | 10:17 AM
Moto One's Avatar
w164 (ml 500)
Your local auto parts store Auto Zone, NAPA act will have the connector too.
Mark.
Old May 9, 2013 | 10:27 AM
N4HHE's Avatar
2009 ML320 Bluetec
7 round to 4 flat? Any place with any trailer parts at all should have the adapter. Its a nuisance and disappointment that M-B didn't go just a bit farther and provide both connectors the way Ford does.
Old May 9, 2013 | 11:31 PM
MLSEXY3's Avatar
I have used both of the Ford pieces and they do not work I will need to custom fabricate a load resistor pack for each channel. The MB computer, did not expect to see minimal current draw of the leds' Almost 1/50th.
Old May 10, 2013 | 12:34 AM
N4HHE's Avatar
2009 ML320 Bluetec
What Ford pieces? As a former Ford trailer hauler owner of 4 years I am not aware of any Ford pieces relevant to towing with a Mercedes-Benz.
That is not the problem you started this thread with.
At $30 this seems a bit expensive to me for what it is but your local U-Haul has a 7 to 4 adapter with load resistors built in: LED Light Trailer Module
