Has anyone tried this?
Old Feb 16, 2013 | 01:32 PM
Chinbold's Avatar
W164 Ml350 & X164 GL450
Has anyone tried to make a custom intake system on their ML350? Any advice?
Old Feb 16, 2013 | 01:44 PM
Chinbold's Avatar
I'm thinking of something like this.
Old Feb 16, 2013 | 03:34 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Why?
Old Feb 17, 2013 | 05:38 PM
paracutin's Avatar
2018 GLE350
Worthless. You will pull in hot air from under the hood rather than cold air from behind the grille. Your hp will actually go down do to the air charge being less dense.
Old Feb 17, 2013 | 10:40 PM
Chinbold's Avatar
So i guess this 1 is better
Old Feb 18, 2013 | 11:33 AM
paracutin's Avatar
2018 GLE350
Yes. With a proper tune you should see a few more ponies.
Old Feb 18, 2013 | 12:25 PM
Chinbold's Avatar
This is what i did today. It really works! I can geel the difference. I've got much more power and acceleration.
Old Feb 18, 2013 | 01:38 PM
paracutin's Avatar
2018 GLE350
What did the dyno say?
I have seen too many independent tests on various vehicles that show the hot air system you installed have a negative impact on actual hp/torque numbers.
Here's a simple way to test the results. Use any GPS app for your phone and measure your acceleration. Swap your old air intake system back in and see what the difference is.
It looks cool and they definitely sound cool but they do not add performance.
Old Feb 20, 2013 | 05:47 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Interesting setup and comments.I am amazed at the concern over drawing " hot air from the engine compartment" into the motor.The vehicle only draws hot air when bits stationary.I am sure the motor "breathes" better.Wether or not it adds ponies , only the sumo knows.
Old Feb 20, 2013 | 05:49 AM
C43AMG's Avatar
Veteran: Army
Stupid iPhone ....."only the dyno knows"
Old Feb 20, 2013 | 06:39 AM
Chinbold's Avatar
It's -20C here and theres no chance to suck hot air while driving.
Old Feb 20, 2013 | 08:09 AM
paracutin's Avatar
2018 GLE350
This is the solution one company has come up with for full size trucks.
http://www.bankspower.com/products/s...C6.2%2C8.1%7C3
While the application may be different the principals of air temperature and density remain the same.
Your setup looks cool and probably sounds cool too but don't be fooled into thinking you are making more power. That's all I'm trying to say. If you want to make more power get a tune to go along with the exhaust you installed a while back.
Old Feb 20, 2013 | 08:27 AM
Chinbold's Avatar
Ok thank you for the advice. I can't measure the exact horsepower since there is no dyno or professional tuning shop in mongolia. Next i'm looking forward for a manifold system. But i'm not sure with ECU tuning since it will shorten my engine life. Whats better?
Old Feb 20, 2013 | 09:38 AM
N_Jay's Avatar
Your intake is BEHIND the radiator.
Go to radio shack and buy a cheap indoor/outdoor wireless thermometer and double check you ASSumptions.
Old Feb 20, 2013 | 10:43 AM
paracutin's Avatar
2018 GLE350
ECU tuning will not shorten engine life. Your driving style will. Lack of regular maintenance will but tuning itself will not.
paracutin's Avatar
2018 GLE350
+1
Old Feb 21, 2013 | 01:15 PM
C43AMG's Avatar
Veteran: Army
ECU tuning on a NA motor in MOST cases is useless
Old Feb 21, 2013 | 01:27 PM
paracutin's Avatar
2018 GLE350
What is an 'NA' motor?
Old Feb 21, 2013 | 01:34 PM
BillsBenz's Avatar
2010 ML350, 2010 GLK350, 2010 C350 4matic
Normally aspirated or a non turbo charged engine.
Old Feb 21, 2013 | 01:50 PM
paracutin's Avatar
2018 GLE350
This tuner has dyno results that show and increase of 22HP and 26 lb ft of torque from an engine tune alone. That's an 8% increase in HP and a 10% increase in torque. Price = $1,000.00. Probably the single largest gain you will find short of adding forced induction.
http://dyno-comp.com/details.php?bro...owse_submit=GO
