Slight grinding noise in front end 2006 ML500
2006 ml 500
Installed new brakes(which were wore out), drive shafts feel firm as do the front axles
no vibration while driving, just the noise.
2010 ML350 and '00 BMW 540i
If you've noticed it right after doing the brake job then I'd start there.
It's possible the wear is on the top inner side of the outer bearing surface. When you jack up the axle and turn the wheel, the lower, unworn side of the bearing is supporting the wheel, thus, no noise when you spin the wheel...........
