Led overdose
Old Nov 28, 2013 | 05:05 AM
yister's Avatar
Ml350
Led overdose
Beast mode
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Scored these on ebay pretty cheap, too much normally. Been looking at them for a while and finally did it, compliments the depo led headlights well. I drove around with the led's on only on my street and actually can see pretty decent.
Old Feb 15, 2014 | 07:54 PM
nievesa1's Avatar
2007 GL450
hi
those look great
can you tell me
what the headlights are like they are xenon correct?
and did you have any issues installing them? were there any disappointments?
thanks
Old Feb 16, 2014 | 02:47 PM
UR2SLO's Avatar
ML
Can you please provide me with the ebay link/seller
Old Feb 16, 2014 | 03:02 PM
nievesa1's Avatar
2007 GL450
hi here you go, I have been eyeing these but not really found any reviews on the forums plus
im concerned about the headlight beam and what the lights looks like when the hids are on
thnx very much
http://www.ebay.com/itm/06-08-MERCED...7ca6d1&vxp=mtr
Old Feb 24, 2014 | 05:40 AM
yister's Avatar
Ml350
Sorry guys, been off the forum a bit. Nievesa, that's the same seller I bought the headlights from. The beam pattern was a bit disapointing on the stock depo/hid pnp solution, so I did the whole retrofit on mine. With the depo's you have to do some dremel inside the housing to get the oe/evox-r hid projectors to fit in there. Here's the thread on the the output shots https://mbworld.org/forums/m-class-w...ml#post5735793
Ur2slo, you can get any of the sellers on ebay on the drl's, they're all pretty much the same. I bought it from a private seller who didn't need it anymore.
Old Feb 26, 2014 | 02:20 PM
UR2SLO's Avatar
ML
How was installing them? How do they work? Like as drl (always on) on like fogs where you use the switch when you want them on?
Old Feb 26, 2014 | 04:01 PM
yister's Avatar
Ml350
Take out the stock fogs, cut some of the plastic bracket around the fog mounts. Not too hard, just be steady with a dremel. You will however loose your fog light function. I never used mine, so didn't matter to me. The new led/bezel just snap in where the stock bezel was. It comes with a resistor pack to connect to stock connector to fool the computer. Then connect the drl controller to the new leds and hook up ground and ignition/battery. I have mine on all the time 2full power. I tried a different controller to dimm them when lights on, but didn't work. My 50w hid drowns them out anyways.
Old Feb 26, 2014 | 04:57 PM
UR2SLO's Avatar
ML
So essentially after you install these you can never go back to the oem fogs? Im not a fan of the cutting part especially on a car like this.
Old Feb 26, 2014 | 05:40 PM
yister's Avatar
Ml350
Yes, can't go back. Mine's a 06, so nothing to loose. Looks so much better/updated, matches my ml63 grill and the led headlights.
Old Mar 12, 2014 | 01:47 PM
ouroboros's Avatar
986 04 SE
The DRLs look really good - great install. Does anyone know of any links to images where this has been tried on the ML63 pre facelift bumper? Or can they only go on certain bumpers?
On a similar thread, there was one W164 facelift version that had factory DRLs. Anyone know of any attempts to dremel these into other bumpers?
Old Nov 2, 2014 | 01:29 AM
Besh's Avatar
Ml350 edition 10
Is cutting the oem foglight housing/mount necessary? Won't the new led drl snap into place over the old housing?
Old Dec 28, 2014 | 11:42 PM
texasflysuper's Avatar
ML350
Did you install a seperate DRL relay switch when you fitted these?
