Replacing brake pads
Calipers are held on with 18mm bolts. Rotors are T?? torx screw, not hex. Not sure on size.
18mm is a less common size, I had to buy it separate as my set had only 17mm and 19mm.
Just did the rear on 06 ML.
So not sure what you're talking about.
What I'd like to know is where to adjust the slack in the ebrake cable.
Already adjusted parking brake pads.
2009 ML320 Bluetec
Only had up to T50 today while the sun was still shining. I think the front might be a T55, but don't go betting the farm because I said so. Am going to find the right answer but it might not be next weekend as replacing the rears muted the idiot light.
Bought full set of front/rear Akebono ceramic because for the same reason one would replace both front or both rear shocks I want the same coefficient of friction on all 4 corners for the ABS, stability, and traction control systems to stay in balance.
The caliber pins are HEX (yes you can get a Torx to fit) and I think are 7 or 8 mm.
The caliber mount bolts are 18 mm
