HELP! Transmission problem
Fault: After the vehicle has been driven for at least 30 to 40 minutes, the transmission pulses when under light to moderate acceleration between the 40 - 60 KMPH. It occurs more often when driving uphill but sometimes occurs on level roads.
Pulsing, modulating or jerking motion is the best description. It is not a shuddering or slipping motion.
Gear changes are smooth.
A transmission shop found a broken seal inside the torque converter. They rebuilt the torque converter but this has not rectified the problem. Could this be a fault with the Torque Converter Lock Up Clutch ,or the adaptive software or transmission solenoids or valve body? Any ideas out there?
