Difference between USA & Canadian built ML63?
Anyone know the differences between a USA and a Canadian built ML63? Whether it be powertrain, features, or maybe wireless frequencies used in the TPMS or the Keyless Go?
Also, can the speedo/odometer be programmed to read MPH/Miles without changing the cluster?
Any other differences that I should know about?
You can change it to MPH in the settings menu. You will see the MPH light will illuminate instead of the k/hr and the speedo will recalibrate accordingly.
The ml doesn't need a cluster change. Through the settings you can change it to Km/h or mph.
Only downside is your cluster will show less top speed on the gauge topping out at 180 or whatever the Usdm cluster visual limit is at.
DRL's can also be turned on with the Star software.
This programming MUST be changed by a DAS/Star system only. There are no user configurable settings between US-Canada.
However, what's causing confusion is that you can enable a second digital display of mileage in the cluster, along with the analog gauge. This only works one way, can't remember which (I think the Cdn ones can show a digital "MPH" but not the other way around).
Other than the second digital display, the entire cluster has to be recoded. It's simple with STAR.
I coded mine from US to Canada when importing the car. Restarted the car and it came up in KM/H, I know have a second "MPH" digital display, and everything else as if the car was sold in Canada. You can't tell by looking at my cluster that it was originally a US car.
So unless you're importing a Cdn car into the US and want a digital "MPH" number showing up (with a useless km/h speedometer that you can't use), just get it re-coded to the proper country. The physical hardware and software in the cluster are identical, it's just one "country" setting that is different.
I have the menu path for DAS stored somewhere if anyone needs it. Might take me a week to dig it up, but I know I saved it.
One thing that people tend to overlook when importing CDM cars that might potentially be a big deal is that the climate control dials will still read in °C instead of °F, and you can't change that with just a few button pushes. Any temperature readings in the cluster will also remain °C (coolant temp, oil temp, outside temp, etc.).
If you are still interested in importing a CDM-spec car into the US and had any questions on the process feel free to PM me. I should still have the direct contact to the person at MB Canada that does the research and issuance of the compliance letter needed to get the car into and registered in the US. And there's a company that I can recommend that does a pretty good job of dealing with customs and getting the car through the border.
Here's my 320mph speedo...fastest AMG ever!
Thank You!
