fault code 9313 can bus low short circuit to GND
Only thing what is found by star is fault code 9313 can bus low short circuit to GND
So i think that is some device or bad wiring what is causing this, or?. Has anyone got same problem ? That will help me a lot. Checking the wiring and all devices is a huge job
can bus high <-> can bus low)
If there is some usual place where wiring broke , tip would be very useful?
Where i find wiring diagram?
More I believe some device which is part of can bus is defected and causes short circuit to ground. is that possible?
It was connected to radio (Audio 20), because only problem without this specific can wire is that you have to put radio on by hand every time you start engine. There is no "awake" signal to radio anymore. Thats why i havent yet tried this with new Audio 20 device..
So my guess is that with this car problem is Audio 20 or broken can wire.
If you find your faulty wire please report here
You can find pics of x30/7 connector from google to know how its look like..
