W164 seat belt tensioners and crash system
Old Nov 1, 2016 | 04:35 PM
MrMcGoohan's Avatar
ML350 W164
Exclamation W164 seat belt tensioners and crash system
hi all! can anyone offer advice: the seat pretensioners in my W164 ML350 keep going off! constantly. the front passenger seat lowers as well, all part of the pre crash safety system fitted to my car. anyone know what the fix is? is a crash sensor going nuts or is it a fault with the entire seat belt system? if i take the fuse out for the pretensioners (no 24 i think - as a short term fix) will it have any knock on effect to any other system?
Old Nov 2, 2016 | 05:45 PM
NvidiaNerd's Avatar
2007 Mercedes Benz ML320 CDI 3.0L V6 TurboDiesel
do u mean you are having problems with ur SRS, if so that it is most likely a sensor inside the belt buckle
Old Nov 2, 2016 | 05:51 PM
MrMcGoohan's Avatar
ML350 W164
It's srs
No.. it's not the srs... it's the tensioners firing off all the time. I suspect (hope) it's just a faulty crash sensor. But there's loads them!
Old Dec 22, 2022 | 07:14 PM
spookster's Avatar
W164
Hi I know this is an old post but have been getting this same issue. Did you ever solve it?
Old Jun 21, 2023 | 10:04 PM
Gillianmck's Avatar
W164 ML320
I'm having the same problem! Has anybody successfully fixed this issue?
Old Jun 21, 2023 | 10:31 PM
spookster's Avatar
W164
I had the bake booster replaced last month under the factory recall, it has only happened once since then
Old Jun 22, 2023 | 02:39 AM
Gillianmck's Avatar
W164 ML320
I just pulled out fuses 24 and 29, which are the driver and passenger side seatbelt pre tensioners and taken the car for a 2 hour drive and it solved the issue. It has disabled the presafe system but i dont care.
Old Mar 5, 2024 | 01:59 AM
mshepstone's Avatar
@gillianmck Does pulling the fuses not leave the SRS light aluminated all the time?
Old Mar 7, 2024 | 04:39 AM
Gillianmck's Avatar
W164 ML320
Yes Ive got lights on and warnings coming up but I just ignore them. It's driving fine.
Old May 29, 2024 | 06:39 PM
Statesman's Avatar
Mercedes 320 cdi w164
Seat belt pre tensoner
Hi mate, got the same problem did you get sorted
Old May 29, 2024 | 10:57 PM
Gillianmck's Avatar
W164 ML320
No I never got it sorted. I sold the car to a friend who doesnt care about the issue. Hes still driving it around without those two fuses.
Old Jun 22, 2024 | 07:12 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi, I know this is an old post. Would you please let me know how to get to this sensor. The SRS on my ML500 driving me crazy. Thank you.
