ML 350 Bluetec Tires
Old May 2, 2017 | 07:28 PM
dfranks61's Avatar
ML350 Bluetec
I've been replacing my tires on my last two vehicles with runflat tires, but I saw a tread earlier on the GL that said it was OK to put regular tires on for a better ride. Can I do the same here? I'm less concerned about the cost as to the ride and what happens if I get a flat tire.
Thanks,
Doug
Old May 2, 2017 | 07:57 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Yes, you can replace your Runflats with regular tires. Many people do it and mainly for a better ride. My 2015 ML350 has regular tires so I don't know how it would ride with Runflats, but my second car is a Mini Cooper and most owners switch from Runflats to regular tires. It should be no problem at all.
Old May 2, 2017 | 08:05 PM
ItalianJoe1's Avatar
2003 CL 600
The only real downside to switching out to non-runflats is the fact that if you have a tire failure you don't have a spare. You can get a little pump and sealant, which is how some of the new cars deal with that, but if there's catastrophic damage it won't help. However, that is also true of runflats, if something tears a chunk of sidewall out you still can't really drive on it.
Only perfect solution is to purchase a spare tire to keep in the vehicle, but that eats up cargo space and adds cost which not everyone is willing to do.
The general benefits of better ride/noise/tire life are so worth it though, run flat tires are just terrible compared to regular tires.
Old May 2, 2017 | 11:03 PM
dfranks61's Avatar
ML350 Bluetec
Thank you for your input. I've never had an issue with tires (kind of like auto insurance that I've never used- well at least 25 years or so) I think it's worth the small risk to get a better and quieter ride.
Best,
Doug
