Dashboard lights flickering and speedo clocks on
And battery drain when this occurs.
There was moisture in the SAM compartment, water in the compartment behind left tail light; water/moisture in the rear tailgate plug and motor compartment.
Now everything above is dry and clean.
There was rain again for two days, but everything is dry. But the problem starts again
Have you checked for water where the battery and the front SAM are located?
Two fuses power up the Inst. Cluster:
1. fuse #11 in the Cockpit fuse box at the right side. That fuse also powers up the Exterior Light Sw.
2. fuse #55 in the Cargo Area fuse box.
With removal of fuse 55 the flickering stops (my test last night). This morning i left the car to my mechanic and he will test for parasitic battery drains, SAM checks and so
My question is what module; ground; corrrosive things can send signals to those fuses - 10 and 55?
Can it be a CAN problem or something?
Bad wiring somewhere ?
I mention this story because your mention of moisture inside the vehicle, along with the video of the symptom, suggests a hail-mary longshot to me... moisture-induced corrosion in the ignition switch/contacts?
But still - the fuse holders can be spray with contact cleaner, right?
If nothing there, then I would check connectors to anything that leads to the start switch, but I am not an MB maintenance guru like Maj Dundee. I would, however, pull connectors that may even be remotely related and look for evidence of corrosion, such as any powdery film, usually white- or grey-colored.
And while you're at it, go get yourself a couple of large dessicant bags and hide them under the seats to get that moisture out of the cabin. If it is the cause of the problem, it will only get worse if you don't get things bone-dry, pronto.
So the problem is that something (module, front SAM) send signals to the dashboard to flicker the cluster lights.
I need a wiring diagram from the dashboard to the other modules that have access to the dashboard. Can someone give me wiring scheme or something?
What is connected to the dashboard, except the front SAM module?
The minus plug for the battery was changed, the SAM cleaned.
Now the weather is rainy and there is a "live"test now.
Minus plug and Plus plug - both plugs attached to the Minus and/or Plus connectors of the battery.
The water entry is caused by faulty tail lamp seals or a drainage problem at the sunroof.
