2011 ML350 diesel No start, intermittent no crank
Old Nov 9, 2017 | 02:12 AM
BCBENZ's Avatar
2011 ml350 bluetec
My 2011 Ml350 just doesn't want to run. Here is a chronological history of its issues
Bought the car in June.
August this year the car sat for 3 weeks and the battery was dead when I returned from out of town. I jumpstarted it and it ran fine for a couple of weeks.
It started having intermittent no crank, no start problems. It would fire up after trying 3 or 4 times.
The intermittent no start problems turned into intermittent stalling problems. Sometimes while driving, sometimes while idling.
I pulled the OBD codes and it said low fuel rail pressure and system voltage malfunction.
MB dealer replaced the fuel pump. The car ran fine for about a week.
Intermittent no crank, no start and intermittent stalling problem returned. The OBD code showed p0560 system voltage malfunction.
The car will now do one of the following.
1. No crank no start
2. Crank and start for a few seconds and die
3. Very rarely it will run for 30 seconds- a few minutes then die while driving.
The battery was tested and it passed
The car consistently shows a p0560 code
If the battery gets lower then the low fuel pressure code returns as well as glowplug codes.
Please let me know if you have any ideas!
Thank you!
Old Nov 10, 2017 | 11:49 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Code P0560 is not a valid code for your model and year. What is the description of the code number?
Old Nov 10, 2017 | 05:24 PM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
I would venture to guess you need to replace your battery. If it loses charge entirely the ECM will tell you when you jump start it or replace the battery. You should take the battery to be checked out. If the battery is good then you might want them to check the alternator.
Old Nov 16, 2017 | 02:15 AM
BCBENZ's Avatar
2011 ml350 bluetec
p0560 is the code i got from my innova 3020b scanner. its a pretty basic scanner. the description I found online says system voltage malfunction. Is there a place I can find a list of codes that are valid for my year/model?
It is definitely not the battery. I just threw in a battery from another vehicle and had the exact same situation.
Also when the car was running I tested the voltage and it was above 14, leading me to believe the alternator is find.
The car now starts consistently, runs for 2-10 seconds then stalls. After the first time it starts it only runs for 1-2 seconds then dies.
Old Nov 16, 2017 | 02:54 AM
There are no "P" codes any longer, especially with diesels.
File Type: pdf
Old Nov 16, 2017 | 06:11 AM
flybd5's Avatar
You're going have to take it to the dealer to put it on their computer and find out what else is being reported. P0560 appears to be a generic code, not a specific fault code. Either that or get yourself a scanner that can read all the codes.
This scanner is recommended here. This scanner is recommended here.
