No power in cigarette or any 12v outlet sockets
Old 12-06-2017, 11:26 AM
Londonml's Avatar
Ml320 cdi w164 2006
Sorry ignore my typo was outside testing it and autocorrect on my phone changed “I just” into “mom” 😬
i’ve just bought the truck and have found a few things up with it since buying. Not much but annoying enough to try and fix them and the main is no power to any sockets which I need for phone charging.
Old 12-06-2017, 11:53 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
With the key out of the ignition, remove conn. G and see if there is any corrosion on the plug or on prongs in the SAM.
If there isn't, reinstall the plug and find a used rear SAM Module in the European market, part #164 900 51 01, which came from an OM642 vehicle. Then it will be plug & play will no coding necessary.
Old 12-06-2017, 12:03 PM
I changed the part number, make sure you search for the correct part.
Old 12-06-2017, 12:14 PM
Londonml's Avatar
Ml320 cdi w164 2006
Darn I Was hoping it wouldn’t be the sam!
ok I’ll try to disconnect it and check for corrosion tomorrow fingers crossed that’s what it was.
If not I guess I have to weigh up wether I buy a used sam or just go without power sockets...
i may just wire wire in a usb connector for my phone and steal the power from the stereo.
Cheere for you help maj amd ill update with the results
Old 12-06-2017, 12:21 PM
Don't do what you are thinking about the radio. Let me see if I can find a work-around.
Old 12-06-2017, 01:00 PM
Londonml's Avatar
Ml320 cdi w164 2006
Ideal thanks!
Ill need a live wire ideally that comes on with the ignition on to prevent battery wear
Old 12-06-2017, 01:07 PM
  #32
Originally Posted by Londonml
Ideal thanks!
I am aware of that and the work around will only power up the front charging socket.
Old 12-06-2017, 01:20 PM
  #33
flybd5's Avatar
2014 Smart ForTwo Passion Cabrio
Ouch. €350 used on ebay.de but not from OM642.
https://www.ebay.de/itm/Mercedes-W16...YAAOSwDkVaIQdR
Old 12-06-2017, 01:34 PM
  #34
They make them expensive because they know there is no programming necessary.
Old 12-06-2017, 02:16 PM
  #35
Go to conn. G again:
1. with the key out of the ign, test wire #13 Blue/ White. There should be no voltage.
2. turn key to on pos. and test again. There should be voltage.
Old 12-10-2017, 12:18 PM
  #36
Londonml's Avatar
Ml320 cdi w164 2006
Solved
So after all this fannying around, I thought I’d buy a second hand relay the grey box under fuses 44-46.
Fitted and boom it’s sorted the problem...
Quick Reply: No power in cigarette or any 12v outlet sockets
