Brake lights issue
I have not taken the lights out to do this - just the globe holder - so quite easy - just had the logic that the original had two hard surfaces (steel) mating and if one was softer it would make a better conection.
been concerned about removing the arced material from the galvanised steel so as to minimise corrosion
Ended up changing my brake light sockets to these on amazon. $12 each, work great and make great connection with the plate
using my phone and video with light on I could see the corrosion spots...
I then removed the contacts from the black sockets... and rinsed them in alcohol and then rust remover. I then scoured them with a wire brush.
Using gloves and qtips... applied rust remover to the corrosion spots on the light assembly plates... then scraped the remaining corrosion off using a dentist pick... steel pick....
All cleaned and scoured.
Put the lights back in, don't attempt LED BTW. Unless you get the correct ones... canbus i think.... anyway...I didn't... they register a fault ... so using the conventional lights.
All is good.
I considered nickel plating the contacts but stopped short. Figured it'll be good for many years to come..
Note the photo below shows the green corrosion... scrape that clean, plus the contacts for the bulb and you should be all set... some of my bulbs also had corrosion... but still work!
Here's another quick gif of cleaning the green corrosion off the plate.
Cheers for the reply, the nice write-up, and the photo.
This is such a brilliant write and repair instructions, thanks to all the great information.
