ISM Location
You are on the wrong forum.
https://mbworld.org/forums/gl-class-x164-77/
It is on the outside of the transmission but after replacing it, it must be coded with STAR.
I do not think it is an ISM problem but I think it is a trans fluid problem. Either it's low on fluid or maybe the filter is clogged.
Check for leaks at the trans and also the lines at the radiator.
For the last time, you must own your own scanner.
