I screwed up. No crank, no start. Help
2002 ML 320 & 2006 ML500
All of these 3 codes refer to connector "C" in the rear SAM. I can almost guaranty that you have or had water entry causing corrosion in connector C.
Key out of ign. and remove NEGATIVE batt. cable. Then remove covers on SAM and look for corrosion.
BlackML550 (11-23-2023)
Engine Fuse box
The following 2 users liked this post by jeff-star:
BlackML550 (11-23-2023),
Joshinator99 (11-22-2023)
I think I've narrowed down to this exact problem. How did you open the SAM? There are five clips but I'm having difficulty undoing them to get it open.
