Transmission oil 236.14
W164 2009 ML350 4MATIC
I want to change transmission oil & there are 2 choice of oil brand which i can't decide which one to buy.
1. Mercedes-Benz geniue oil 236.14.
2. TITAN oil 236.14.
I do not need cheap oil & i prefer quality. Can you guys advice which one will work best ?
There is no "best". Any one on this list will do.
https://bevo.mercedes-benz.com/bevol...4&suchbegriff=
You are missing the boat on the fluid. If you price 10 oils in 236.14 and one of them is two dollars cheaper than the others, then get that oil.
Again any oil in the sheet can be used. And Shell is a very good oil.
Dundee is correct. You can use any oil in the sheet. Mercedes does not produce oil, it only packs the oil produced by third parties. And the origin of the oil depends on where it is sold. For example, here in Brazil the Mercedes-Benz oil is produced by Ipiranga.
So, we bought the oil from Ipiranga to put in the car for half the price. It is the same oil sold by Mercedes.
Thanks for all for your assistance for making right choice.
