2008 ML 320 CDI (W164) - code P0408
This is the that you should have bought.
When I clean this code I can drive for hours nothing happening, but when I shut of engine and restart the code is back.
I am skeptical the EGR is defective?
Did you ever get code 2045 Crankshaft Sensor?
I never got 2045 code.
There is no grey-yellow wire on connector but Red-green instead.
When I measure there is 12 V (red-green wire) when the engine is turn on and the power getting to zero after is turn of.
I am not sure should power on this wire be permanently on or not.
Why are you concerned about the RED/GRN wire losing power when you shut off the eng.? Be concerned when there is no voltage while the eng. is running, which is not occurring.
Monitor all three wires while the eng. is running, Red/Grn for 12 v, & Brn for GROUND with a DVOM. Check each wire for at least 30 sec. to see that you never lose the voltage or ground.
