Help! Anyone know the air filter part # for a 2012 ML350 bluetec?
Old Jan 27, 2019 | 10:49 AM
keman58's Avatar
2012 ML350 Bluetec
Does Anyone know the air filter part # for a 2012 ML350 bluetec? I was given 1120940004 but they won't confirm thats the one.Thx!
Old Jan 27, 2019 | 04:14 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please post you full vin #.
Old Jan 27, 2019 | 05:20 PM
keman58's Avatar
2012 ML350 Bluetec
The VIN # is 4JGDA2EB4CA040158. Thx!
Old Jan 28, 2019 | 01:36 AM
Here is the correct part # according to your vin#. Also a copy of your DATA Card.
File Type: pdf
Old Jan 30, 2019 | 01:12 PM
keman58's Avatar
2012 ML350 Bluetec
Thanks so much.... every time we want to order something from eBay they ask us ti check part# 1120940004. Seems as if we can't confirm whether that would fit the vehicle or not!
Old Jan 31, 2019 | 06:49 PM
lkchris's Avatar
'10 CL550, '12 GL550
Be sure to review the official WIS procedure for air filter change for your model.
on my diesel (2007 GL320CDI . same engine) after hanging the filter a computer reset operation is required. Apparently asensor is monitor filter restriction. Have never seen much on forums about this, whether it will automatically adjust when seeing less restriction or not,etc.
imho air filter change is not a diy operation on these engines
Old Feb 1, 2019 | 06:07 AM
Here is the procedure.
Old Feb 1, 2019 | 07:43 PM
lkchris's Avatar
This is procedure for 166.
For 164 there are three procedures ... Remove/install air filter housing (left), Remove/install air filter housing (right), and Replace air filter element.
The latter for 164 is AR09.10-P-0980GZD
The final instruction is "Reset quantity mean value adaptation data using STAR DIAGNOSIS."
Old Feb 1, 2019 | 11:14 PM
I don't understand what you are trying to say, the OP has a W166.
Old Feb 2, 2019 | 05:33 PM
lkchris's Avatar
This is the W164 forum ... but in any event might confirm WIS for 166 doesn’t mirror 164 if having procedure for changing filter that references separate procedure(s) for removing the airbox. Curious whether the computer reset requirement is really gone.
