Windshield defrost is not blowing/working
Old Jan 29, 2019 | 01:40 AM
Dd1's Avatar
Dd1
Mercedes ML 320 CDI W164 2009
Hi all,
I recently got my ML and really love it. However there are some issues that I have. One is that when I try to defrost the front window, nothing happens. Pushing the defrost button and all of the air is going through the passenger and driver’s blowers only - no air from the window blower nor from the fixed vents on the doors.
Any help would be appreciated!!
Old Jan 29, 2019 | 02:42 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE in USER CP to include the year and where you live.
Old Jan 29, 2019 | 02:48 AM
Originally Posted by Dd1
Hi all,
Very difficult to understand what you are trying to say. When you say "blowers", do you mean the vents? Please explain better or make a video.
Do you have a scanner?
Do you have an owner's manual?
Old Jan 29, 2019 | 03:18 AM
Dd1's Avatar
Dd1
Yes the vents. All the vents for defrosting are not blowing any air. By defrosting vents I mean under the windshield, plus the fixed side vents.
No I do not have scanner.
And I do have the manual but how it will help me with this problem?
Old Jan 29, 2019 | 04:25 AM
Thanks for updating your profile.
I asked about the manual in case I find something you can refer to.
Will air come out of the center vents and the right and left vents if you select that with the dial?
Did you buy the truck with this problem or did it recently happen?
Old Jan 29, 2019 | 04:42 AM
Dd1's Avatar
Dd1
Hello Maj. Dundee! Thank you for the fast reply.
I tried all possible combination but air is not coming from number 1,4 and 9 from the attached picture which I downloaded from the old manual.
I bought it recently so I found that these days.
Also I have noticed that the rear vents does not blow any hot air. Cold air is fine for rear vents, though.
Post your full vin#.
Old Jan 29, 2019 | 04:46 AM
Dd1's Avatar
Dd1
WDC1641221A495903
Old Jan 31, 2019 | 12:53 PM
Dd1's Avatar
Dd1
Maj.dundee did you manage to find something? Or can someone send an instruction how to get there so I can check if it is an actuator or some broken lever?
Old Jan 31, 2019 | 04:04 PM
CLK Group's Avatar
2008 ML320CDI 4Matic, 2006 C350
Occasionally some of the levers may get stuck in the closed position. Try this fix:
Select the vent setting not working.
Set the Temp up to maximum.
Turn on Auto.
This will force all air thru those selected vents.
In Summer set the Temp down to the lowest setting you have.
Old Feb 1, 2019 | 03:27 AM
Dd1's Avatar
Dd1
Thank you for your answer CLK group. I am afraid that this method won’t work. Usually what you are telling me is the same as pushing defrost button - maximum power to the vents that are not blowing any air. If i select manually the button windshield accompanied with the vents for the footwell , again to maximum power - no air is coming on the windshield.
Old Feb 1, 2019 | 03:38 AM
Unfortunately any problem with the A/C requires the removal of the top half of the Instrument Panel.
So, to make any call on this would require that the codes be read in the AAC Control Mod.
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 1, 2019 | 03:51 AM
Dd1's Avatar
Dd1
Yep, does not work. Any ideas how to get to the actuators?
Old Feb 1, 2019 | 04:16 AM
Do you really want to remove the IP without reading the codes to support it? It could be the AAC Cont. Module and then all the removal would be in vain.
Here is the first procedure so let me know if you want all the rest of the RED procedures on the right.
Old Feb 1, 2019 | 04:23 AM
Dd1's Avatar
Dd1
Hmm you have a point. Probably I will give it to the service to leave them deal with it. It is not an easy task thank you!
Old Feb 1, 2019 | 05:51 AM
Insist that the codes be read with a scanner. Let them give you the code/s numbers and compare it to the list that I supplied you with.
