No Power to Fuel Pump... 2006 ML350
no, i actually did not clear the code... i didn't even think about it, i just figured the ECU would check for a signal the next time the key was cranked...wrong assumption? lol.
I did check the fuse, it's a 20 amp just right next to the relay, i've swapped the relay with horn relay, and that checks out good. I guess I'm gonna go borrow the obd2 reader again and clear the code to see if it starts... if that's all it is, i'll be rather let down about all i've done trying to chase this down...but relieved all at the same time... thank you!
2. did you check to see if code P0335 is still stored?
3. Does the eng. crank when turning the key or nothing at all?
4. did you check to see if the connector is snapped in on the CKP Sensor?
5. also check fuse 51 in the cargo area fuse box.
6. is the relay you checked KO in the rear fuse box?
2) p0335 is cleared. It also had other codes related to the fuel circuits, i cleared those, and figured they had occurred due to all of my plugging and unplugging for testing.
3) the engine cranks just fine, will start with a little gas put in the throttle body, and after i jumped relay "O" across pins 3 and 5, fuel pump kicked on, and i was able to start vehicle with pressure after i removed jumper, but still wouldn't remain running.
4) the connector is in as far in as it will go on CPS (i would like to check the other end of the connection to where the CPS sends it's signal to check for continuity/signal, but I do not know where it goes)
5) 51 fuse is good.
6) i'm not sure what relay "KO" is... I have relay "K" which is for power seats and relay "O" is for the fuel pump. relay "O" is identical to the horn relay in the front compartment, i swapped to verify relay is functioning.
Maxwell, you have found your problem. Rain water entry due to faulty tail lamp seals. This must be addressed first to stop future water entry. When you remove the lamps you will see that the seals are attached to the lamp instead of the body opening.
Did the residue look like this video? If so, the SAM must be completely disassembled towers included and cleaned with toothbrush & electronic contact cleaner.
It is impossible that there are no codes stored in the 25 or so modules in your vehicle. If you are just using a cheap code reader, it is useless.
You must have a scanner that will scan the entire veh. They even have codes for the fuel system.
https://www.amazon.com/Autel-MD802-M...autel+maxidiag
You just supplied your vin# but completely ignored the rest. If you do not have a scanner everything will be guesswork.
this car had been repoed back in october and has pretty much set up until i purchased it... it had an empty tank, (i guess they didn't have money for gas neither..lol) and i'm sure that didn't help it... i would have ordered a pump a week ago, but said i wasn't going to buy the pump until i was sure that it was the pump, and up until today, it hadn't been the pump... gonna go ahead and replace the filter and sending unit on the driver's side of the tank while i'm at it, and hopefully that will be it for awhile.
i'll post another update with the pump arrives and is installed.
another note on the cabin covers for the tank... all the other ones i've seen on every ML online appear to have a little adhesive under the lid.. mine, on the other hand, (and it appears it was done this way before factory paint) was cemented to the floor pan both under and over with a good 1/2 inch of adhesive...i don't know if the assembler thought they were doing someone a favor by going that extra mile... but i had to punch out the covers
probably could have cut them out, but i didn't want to do something like cut through the top of the tank or a fuel line or wiring..
