Command ntg 2.0 problem
Old Mar 27, 2019 | 02:44 AM
BRENDAN BURKE's Avatar
2006 ml350 petrol v6
G'day all? I have recently had a problem with my W164 command system. It began after I had a battery issue, the main battery was replaced and the back up battery was tested. My problem is it powers up to the MB logo then powers down after a few seconds. All was working fine prior to the battery failure, I have tested evey fuse in the four fuse boxes including the one under the seat. I am unable to get it scanned easily because Im about 500klms away from the closet service centre. Any help would be appreciated. Thanks Brendan
Old Mar 27, 2019 | 04:25 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Brendan, turn the key to the on position and with a test light or DVOM, check both contacts on each fuse for 12v. Fuses 20 & 25 in the load compartment fuse box.
When you changed the battery, was the key in the ignition?
Old Mar 27, 2019 | 05:50 AM
Thanks for your response, I have checked those two fuses all ok, the kwy was in the ignition at the time
Old Mar 27, 2019 | 06:54 AM
Did you check them as I suggested?
NEVER leave the key in the ign. when replacing components or parts, especially when needing a jump start..
Are there any other features that are not working?
Can you post a short video of the screen fading out?
Old Mar 27, 2019 | 06:58 AM
I forgot to include this photo of the fuse checking for 12v at the two contacts.
Old Mar 27, 2019 | 07:37 PM
Thanks for your reply, I have check both fuses and they are ok, I can also eject the Navi disk from the command unit. I'm unable to upload a video as the file is to big. Any assistance is appreciated
Old Mar 28, 2019 | 03:32 PM
Do you mean I can't eject? If so try this remedy.
