Ac problem Passenger side Colder more then driver side
Old May 22, 2019 | 04:41 PM
Roy mb's Avatar
Ml350 w164 2009 and w204 c200 cdi 2008
Hi my mb friend ineed some Advice and help
I riplace a new denso compressor Because there was no refrigerator., cleaned up the system and I put new gas.
The air conditioner is now very cold and the problem is A problem that was even before I riplace compressor that the driver's side is less cold than the passenger's side. It's cold but not like the passenger side.
What do you think the problem might be?
I'm putting in picture from my icarsoft i980 scaner live database
There are no error code.
Old May 23, 2019 | 05:39 AM
Roy mb's Avatar
Ye
Originally Posted by Plutoe
Do you get the same volume of air on both sides?
Yes iget the same air volume
Old May 23, 2019 | 08:23 PM
Roy mb's Avatar
The ac bar is ok? How I know if my ac compressor have Enough r-134a
Old May 23, 2019 | 08:52 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
How many grams of freon did you put in the system, after replacing the compressor?
Old May 24, 2019 | 04:46 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE in USER CP to include where you live.
Then explain the difference between the left and right outlet temp. sensors.
You must check for codes in the AAC Cont. Module.
Old May 26, 2019 | 11:40 PM
Roy mb's Avatar
I have no idea my mechanic added
Old May 26, 2019 | 11:43 PM
Roy mb's Avatar
There are differences in temperature between left and days but sensors show a larger difference, when is not hot outside the air conditioner a good refrigerator on both sides
Old May 27, 2019 | 08:23 AM
Old Jun 1, 2019 | 04:45 PM
Roy mb's Avatar
I checked with a computer, no error.
Old Jun 2, 2019 | 01:55 AM
I do not know what code reader you are using, but with a problem you are having there must be a code stored in the AAC Cont. Module. You need a scanner.
Amazon Amazon
