Electrical problem w/icraft scan
I finally got the icarsoft i980 scanner on my 2011 ML350. I expected some codes and have many. The SAM showed codes of
900C. Not found in database
900D component or signal line to component E6/13 (left standing and park lamp) has open or short circuit
Circuit 30 (1) has an under voltage to ground <7
”. “. “. (2). “. “. “
Control module N73. (EIS[EZS] control unit not sending any data
there are various other code areas like doors heaters. But I imagine the SAM May narrow diagnoses the best
Im embarrassed to say I tried jumping the vehicle with my charge pack (worked previously-on now obviously broken down and since replaced battery)
The whole system seemed to disagree with everything going on and got worse as I tried to start it several times. I started doing a little hunting with the fuses and they appear hit and miss but when I take them out they test fine So I ordered the icarsoft i980 and picked a number of codes. I’m stranded
So your battery went dead and you tried to jump it.
How did it go dead?
Was the key in the ignition when you jumped the battery?
What is the code number for EIS control module?
Check fuse #14 in the right side dash fuse panel.
I just checked fuse 14 as well as the rest of that box and they are all good
Im going to charge the battery on trickle fo r a few hours and run another scan and take pics and notes of everything
And thank you so much for this help.
Front SAM
Front SAM diagnosis
Rear SAM
Rear SAM [no DTC’s]
TY
