Engine fan inop, how to diag?
Old Jul 14, 2019 | 08:38 PM
Towmater's Avatar
Ml350 bluetec
My engine fan doesnt operate / spin. No codes.
Ml350 bluetec 2010.
Is there a relay or module I should check or does this mean I need a new fan?
Old Jul 15, 2019 | 12:26 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
With the eng. running after 5 mins., check fuse #7 in the Eng. Compartment Pre-Fuse Box for 12v..
Old Jul 15, 2019 | 01:22 PM
Towmater's Avatar
Ml350 bluetec
Thanks. Will check.
Also tried to operate the fan with the scan tool and it failed to operate.
Old Jul 16, 2019 | 12:00 AM
Towmater's Avatar
Ml350 bluetec
After undoing the top clips I still cant open the box. How does it come off?
Old Jul 16, 2019 | 03:36 AM
Here are the directions.
File Type: pdf
Old Jul 16, 2019 | 11:26 AM
Towmater's Avatar
Ml350 bluetec
Thank you. I'm grateful for the instruction
Old Jul 17, 2019 | 01:45 PM
Towmater's Avatar
Ml350 bluetec
Fuses good. Replaced fan. Fan works. Thabk you for all your help
Old Jan 26, 2025 | 12:48 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi Major,
Is there a way to get the cover off without breaking the edges. The so called clips look so integrated into the body; it seems impossible to undo them. Thanks
