ISM
Initially i wanted to do that with mercedes dealership, but they are replacing the part with a new only and were quoting me some ridiculous moneys, dont remember now what the price was exactly, over a thousand GBP.
So i found some company which is selling the refurbished ones with part exchange, or refurbishing yours. I bought the refurbished one from them for under 400GBP, fitted it, works well so far (done that 3 years back). You will definitely find some company which is refurbishing them in US as well.
Oh, and another thing, important one: if this error is coming up on the dash, it is not necessary the ISM fault. It can be the ignition module (IZS, i guess), under voltage to this module, or that it is faulty or it could be something else. If i was you, i first would investigate all other probable reasons, you might end up having to just clean the power lines connections. For troubleshooting all of that, you will need the Star Diagnosis scanner.
The ICM has been declared a Theft Relevant Part and that means that you cannot buy it. Only a dealer or approved mechanic shop may purchase and install it. How they legally got away with this is beyond me, but they did. They cornered the market.
Explain what your problem is.
https://www.amazon.com/Autel-MD802-D...ateway&sr=8-3/
Hi
Just getting used ISM from another car and trying to code it to your car is not going to work. It has to be reset first. That can not be done via the star scanner. Some refurbishment company who is refurbishing them would be able to reset it.
Just to let you know so you dont waste your money on a used unit which is not reset.
Also I would check the main battery connectors as well. If they are oxidized and not giving enough voltage on the ignition, that might affect the ignition module feed, which if not functioning right, gives same message, of can not shift go to workshop message. And of course, check the connector on this module itself (ignition module).
Hope that helps.
Hope that helps.
There is nothing embarrassing, the dealerships are ripping mercs owners badly. I never went to them myself and i hope i will not need to do that ever.
However when I hooked this diagnostic tool up to reprogram the servo module I get nothing. Truck is stuck in park in my friends pole barn. I probably am not using it correctly because I have never used one. Was told on this forum it would reprogram the servo module to my truck. Well how do you do that. The scanner says it is not getting information. The scanner does not down load to my computer. What is the deal here Maj Dundee. I bought this on your advise. I admit I've got no clue when it comes to this but i'm frustrated to the max. This shouldn't have been that hard. Can some one who has done this help me out. I can give my phone number to talk personally. Thanks for any help. Spartydano
when i was pairing my car with the ISM i was using Star Diagnosis system, which is used specifically for Mercedeses only. I had to pair the ISM, then perform learning process. I would think the ISM pairing and learning you can do only with the Star Diagnosis.
When Maj.Dundee was suggesting to get the scanner, he suggested to get a scanner which definitely reads the mercedes system and he meant you have to scan for codes and be sure there are codes to the errors you are trying to fix instead of just replacing the parts.
But replacing this specific part like ISM you will need that mercedes scanner. If you would go and buy a genuine one, even used one, that would be very expensive. There are replicas as well, you can find them in chinese market, these are much cheaper, and they do work. Or you have to find someone or some garage who own one and ask for help.
If you will find someone who has the Star Diagnosis system, but never done adaptation, i can look for the steps needed to go through to make it work. I think i still got it somewhere, i was going through that myself.
Also, you originally never said how you determined the problem was with the ISM.
They would not want to have anything to do with some module from third party, as they can not give any warranty etc.
https://rover.ebay.com/rover/0/0/0?m...2F401968655005
thanks for all your advise
The one on your link is the 4th generation one, but it is not enough. You need to have a laptop to which it would be paired to. The laptop has to have specific software installed. If your merc is under 2014 year, you would be enough to get Star Diagnosis C3, the older one, a bit cheaper and it connects to the laptop by wire, i think it is much more reliable.
If you keep searching on ebay or aliexpress, you will find the kit with laptop ready to plug and play, which includes star diagnosis, cables to connect, laptop with the software installed and paired up and so on.
I made a quick search, here are some links of what you need. (If you search further, probably you can find some cheaper listings)
Ideally the link below is exactly what you need:
https://www.ebay.co.uk/itm/New-MB-St....c100005.m1851
If you want to go the cheaper route, you can get C3 generation kit with the HDD only, which includes the pre-installed OS with the software for it to run. So to run this HDD you will have to purchase some old laptop which has got RS232 connection (serial port). Ideally Dell Latitude D630, or Panasonic CF-19 Toughbook. Insert this HDD and run it from that. All would cost a few hundreds less than the first one. I did not search for the laptops, there are loads of them online. Here is the link for the cheaper C3 generation multiplexer:
https://www.ebay.co.uk/itm/MB-Star-C....c100005.m1851
Hope that helps of you decide to go that route.
The bottom line on this repair is to buy a new module (virgin), have accessibility to the Star Diagnostic data base, VIN numbers, including license to reprogram module. You must have this accessibility. Pair or program module to your vehicle VIN number before installing. This is just more convenient. Then complete the install which is a bit tight. (I had to unbolt drive shaft to get upper heat shield screws and module bolts off). You should be good to go then.
I have read & been told a lot about used modules or refurbished. They may not be able to be reprogrammed even after being virginized. The cost of refurbished and new is minimal so I suggest new.
I am still waiting on finding out about getting my install programmed. This has been a real experience. Hope this aids others having the same issues. Thanks to all who responded and helped. Spartydano
