Change of engine and transmission on ml350
Old Dec 11, 2019 | 12:44 PM
mthompson8345's Avatar
2006 ml350
I own a 2006 ml350. Can I fit a 2008 0r 2009 engine and transmission to this chassis. I am tryinh to avoid the balance shaft problem the 2006 model Has. If I fit in the 2008 or 2009 engine, would I have to reprogram anything. I live in Africa and afraid we do not have Mercedes experts here. The car is mint in all other areas and it's only the engine that have been giving me hell. I love the car very much.
Old Dec 11, 2019 | 01:30 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Engines might look the same but wiring harnesses and connectors could be different. Why take the chance of buying an eng. & trans. and then remove both your eng. & trans. and find out your new ones won't work.
Old Dec 11, 2019 | 01:56 PM
2006 ml350
Thanks Maj Dundee. I am now at a loss but is there no way that the harness could be modified to suit the change?
in other words, would the change be just minor?
Old Dec 11, 2019 | 05:08 PM
Forget your hopes and ideas. Try to buy a W163 ML.
Old Dec 15, 2019 | 01:46 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
A 2008 or 2009 is a direct fit for your vehicle you can also use the motor out of a w211 chassis and just swap oil pans and pick up tube
